It is currently Wed Nov 25, 2026 6:34 am
 Post subject: What the....
PostPosted: Fri Jul 11, 2003 12:01 pm
Hey all, i have an Offy 4bbl intake here, the odd thing is i thought these intakes were un-usable with the stock exhaust?
This one is unmodified and is bolted to a brand new exhaust manifold, i was talking about my truck with a guy at a local shop and he said what kind of motor you gonna run, i started getting into the slantsix and what i was looking for and he said i got a cam, intake, and carb off of a slantsix, picked up the whole works for 100bux (was sitting for 7years) but i just dont get it, it doesnt have an egr or anything.... any help on this one? you can also use the stock linkages with the stock kickdown too!!!
the only numbers i could find were under it and it says 6-6-C :shock:
Thanks Guys!
Justin
PostPosted: Fri Jul 11, 2003 12:12 pm
I've run one of these intakes and found that some of the late model stock exhaust manifolds interfere with the mounting. I have a large selection of manifolds and have always found one that works with the offy.
PostPosted: Fri Jul 11, 2003 12:27 pm
hmmmm, but this intake atcually "bolts" up with the exhaust heat riser and all, its got everything except the EGR :shock: :shock: :shock:
PostPosted: Fri Jul 11, 2003 1:04 pm
All the pictures of the offy manifolds I have seen bolt up to the stock heat riser area of a exhaust manifold. I believe it was the clifford manifolds that were supposedly not compatible with stock exhaust manifolds.
PostPosted: Fri Jul 11, 2003 2:05 pm
hah, i guess that explains that!
I just found it odd that it was like this, i have a unknown camshaft here (how can i idenify this thing??) and the adaptor plate, 600holley, intake, and a new exhaust manifold.
Justin
 Post subject: To measure a camshaft...
PostPosted: Fri Jul 11, 2003 4:34 pm
The best way to ID a cam is to send it to a cam grinder and have them measure the profile.
You can sometimes fine ID numbers stamped or engraved on the end face.
One other thing you can do is measure the "lobe lift" by measuring over the lobe tip, then measure across the sides. (90 degrees away) s
Subtract measurment #2 from #1 then multiply by 1.5 (Rocker Ratio) This will give you a rough idea of the cams advertized lift, then you can make an educated guess on what cam it is based on manufacturer's published specs.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 6 guests
