It is currently Fri May 08, 2026 4:58 am
 Post subject: Head gasket
PostPosted: Sat Jun 23, 2018 8:07 am
Car Model: 1965 Dart
I need a big bore 3.58 to 3.66 head gasket that is .040 to .045 compressed thickness.
 Post subject: Re: Head gasket
PostPosted: Sat Jun 23, 2018 8:32 am
Wait....
What size bore have you got, and where did you get pistons?
PostPosted: Sat Jun 23, 2018 8:47 am
Wiseco Pistons I believe it's been bored to around 232 going to put bigger valves need a little more clearance on the edge of combustion Chambers to get the right CC.
PostPosted: Sat Jun 30, 2018 11:07 am
I guess I'm asking for the impossible.
PostPosted: Sat Jun 30, 2018 12:00 pm
This is no problem. The Aussie-made "Endurotec" gasket is excellent up to around 12:1 and is 3.66 bore and 0.046" or so compressed. You can order them from https://www.precisionintl.com/ and the shipping is not too bad. Best to order a spare or two also.
Best,
PostPosted: Sat Jun 30, 2018 12:38 pm
They are on Ebay from Small town speed.
https://www.ebay.com/i/192577556503?chn=ps
PostPosted: Sat Jun 30, 2018 1:01 pm
Thank you!! I was having a hard time finding anything but stock gaskets. Any recommendation on rocker arms would be awesome. Thanks again Lou you the man. LOL
PostPosted: Sat Jun 30, 2018 1:43 pm
I didn't know you could bore a slant out that far.
Escape Velocity Racing
PostPosted: Sat Jun 30, 2018 4:22 pm
You can't :D :D
Most racers are .100 over, some have been .130 over. At least one (In my son's garage) is 3.592" or .192 over! That is on the edge of disaster in my opinion.
PostPosted: Sat Jun 30, 2018 9:14 pm
The gasket is bigger than the bore by quite a bit. This is nice if you want to add bore notches for more smooth flow from the head chamber to the bore. I do this on my motors, making sure I don't grind down into where the top rings are sweeping. Biggest motor I have built is 3.504" and I use the Aussie 3.66" on everything. I bet you can get it cheaper than $80 shipped from Australia (precisionintl....).
PostPosted: Mon Jul 02, 2018 3:23 pm
Factory stock rocker arms are fine.
PostPosted: Mon Jul 02, 2018 3:34 pm
Best,
I have 3 of these on the shelf. Too bad you're so far away, but I can ship it and it will be less than international shipping.
