It is currently Sun Nov 22, 2026 3:28 am
PostPosted: Sun Jun 24, 2018 6:52 am
Need some help finding correct brake parts.
Vehicle is 1984 d-100 slant six A-833od trans. Has had a 8 3/4 rear swapped in. I need to replace wheel cylinders, and shoes, but don't know what application to look up. Wheel cyls are 1 3/16 and shoes are 11x2.5. If need be I could probably figure it out, but hoping someone can save me some time. Thanks
PostPosted: Sun Jun 24, 2018 12:31 pm
I was wrong on the wheel cyl size. They are 15/16.
Looks like brake parts for a 1969 Charger will work.
PostPosted: Sun Jun 24, 2018 4:03 pm
D series trucks had 8 3/4 axles from 71 to 74, IIRC. Rockauto still sells wheel cylinders for it based on brake size. Shop for a 74 D100. But, yeah, you already figured out the cylinders are 15/16.
