It is currently Thu Apr 30, 2026 6:01 pm
 Post subject: piston pin size
PostPosted: Fri Jul 06, 2018 2:34 pm
I`m looking at a set of 2.8l piston but the pin size is .906. will the stock rod need machining to make this larger pin size work?
 Post subject: Re: piston pin size
PostPosted: Fri Jul 06, 2018 2:54 pm
Terry I had the machine shop resize mine. But it may work at factory specs? I don't know. :?: :?:
PostPosted: Fri Jul 06, 2018 4:55 pm
rick what did you have done? the difference is .901" stock so not sure if .906" is a go! one shop said it will but I`m not sure. I just had my first pin move and hurt the cylinder wall but it was a reused piston and pin.
PostPosted: Fri Jul 06, 2018 5:10 pm
I dropped them off at the machine shop and told them what I had. I said to resize them to accept the bigger Chevy pin size. Picked them up a couple days later.
PostPosted: Fri Jul 06, 2018 5:28 pm
did you use the 2.8l v6 pistons? trying to understand the shallow ring description , when I check the piston it takes a standard ring not the shallow!! confusing.
PostPosted: Fri Jul 06, 2018 5:32 pm
Yes 2.8L Chevy pistons off Ebay with standard rings on 198 rods.
PostPosted: Fri Jul 06, 2018 5:47 pm
I`m looking at these with 225 rods in the blown engine with the block surface cut 100th.
Users browsing this forum: Bing [Bot] and 8 guests
