| piston pin size https://slantsix.org/forum/viewtopic.php?t=62555 |
| Author: | terrylittlejohn [ Fri Jul 06, 2018 2:34 pm ] |
| Post subject: | piston pin size |
I`m looking at a set of 2.8l piston but the pin size is .906. will the stock rod need machining to make this larger pin size work? |
| Author: | Rick Covalt [ Fri Jul 06, 2018 2:54 pm ] |
| Post subject: | Re: piston pin size |
Terry I had the machine shop resize mine. But it may work at factory specs? I don't know. |
| Author: | terrylittlejohn [ Fri Jul 06, 2018 4:55 pm ] |
rick what did you have done? the difference is .901" stock so not sure if .906" is a go! one shop said it will but I`m not sure. I just had my first pin move and hurt the cylinder wall but it was a reused piston and pin. |
| Author: | Rick Covalt [ Fri Jul 06, 2018 5:10 pm ] |
I dropped them off at the machine shop and told them what I had. I said to resize them to accept the bigger Chevy pin size. Picked them up a couple days later. |
| Author: | terrylittlejohn [ Fri Jul 06, 2018 5:28 pm ] |
did you use the 2.8l v6 pistons? trying to understand the shallow ring description , when I check the piston it takes a standard ring not the shallow!! confusing. |
| Author: | Rick Covalt [ Fri Jul 06, 2018 5:32 pm ] |
Yes 2.8L Chevy pistons off Ebay with standard rings on 198 rods. |
| Author: | terrylittlejohn [ Fri Jul 06, 2018 5:47 pm ] |
I`m looking at these with 225 rods in the blown engine with the block surface cut 100th. |
