It is currently Tue May 19, 2026 8:37 am
PostPosted: Fri Jul 20, 2018 4:36 am
Car Model: 1984 Ram D150
My NOS Holley 1945 arrived from Tel Aviv Israel yesterday (eBay seller) and I'd like.to mount it up and connect the new electric choke.
Question:. What do I need to do to the carb prior to putting it into service?
I will follow the factory service manual procedures for baseline adjustments.
Thanking you.
PostPosted: Fri Jul 20, 2018 2:16 pm
Well, the 1945 is bolted on and running pretty good, right off the bat.
I have a 1234 electric choke but there was no available hole on the choke butterfly plate to attach the rod.
I would have to remove the fast idle cam rod to attach the choke rod.
Does the electric choke take over the job of the fast idle cam?
Should I just go ahead and unhook the fast idle cam rod to affix that electric choke rod?
Thanks.
PostPosted: Sun Jul 22, 2018 9:53 am
Car Model: Slant Six M37
I do not believe that the choke takes the place of the fast idle cam.... usually they work together... although you may be able to get by with out it...
PostPosted: Mon Jul 23, 2018 6:50 am
Thank you. Yes, I think they should work together which is why I'm loathe to nix the FIC. I have a solution to attempt which is replacement of the choke plate with one that allows for a choke rod. Time will tell...
*see this thread: Page 5 http://www.slantsix.org/forum/viewtopic ... 6&start=60
