| Carter BBD rebuild kits for 8198S https://slantsix.org/forum/viewtopic.php?t=62644 |
| Author: | shadango [ Thu Jul 26, 2018 9:13 am ] |
| Post subject: | Carter BBD rebuild kits for 8198S |
Hi all Looking for some specific carb- kit info-- Carter BBD 8198S --- when engine has been run and is hot, and then parked, fuel begins to percolate and then we get a drip (once every 3-5 seconds) of fuel from the main throttle plate rod.....it comes out, runs along the spring and then drips.... Once the engine cools down it stops. Carb was a new reman in package, still shrink wrapped rebuild from the 80s, and has run good, even now.....was installed maybe a year ago. Upper body gaskets are looking soaked though. Some good folks on the F body forum say its likely the float out of whack or dirt in the needle seat or maybe a hard seat. And that makes sense.....the carb, though "newly redone" was sitting for who knows how long. SO I need a rebuild kit. On rock auto they list a parts kit for the 80 Volare 2 bbl, but specify : Fits2BBL; w/ Carter Carb.; w/ Mexico Emissions; BBD; 8314-8315 Or2BBL; w/ Carter Carb.; BBD; 8250, 8286-8287; w/ Canada or Export Emissions So the query for all the slant 6 carb gurus here.....is this kit gonna work fine? Or keep looking? Looking here http://www.carburetion.com/SiteCarbNumb ... and=Carter, it seems like they are the same kits and floats....but......want to be sure Thanks all! |
| Author: | matv91 [ Fri Jul 27, 2018 9:02 am ] |
| Post subject: | Re: Carter BBD rebuild kits for 8198S |
8198s was for 1979 225 auto, federal emissions sedan weight class 3500 lbs and may be canada. In the us mid year running production change,8198s was replaced by 8264s . 1979 was last year for us bbd on cars for slantsix,still used in canada in 1980. Carter zip kit 902-325b 225 bbds 1977 -1980. |
| Author: | shadango [ Fri Jul 27, 2018 9:57 am ] |
Quote: 8198s was for 1979 225 auto, federal emissions sedan weight class 3500 lbs and may be canada. In the us mid year running production change,8198s was replaced by 8264s . 1979 was last year for us bbd on cars for slantsix,still used in canada in 1980. Carter zip kit 902-325b 225 bbds 1977 -1980.
Thanks! From what I can figure, looks like the kit we bought covers multiple years, including our 8198S.
