It is currently Wed May 06, 2026 6:28 pm
PostPosted: Thu Jul 26, 2018 9:13 am
Hi all
Looking for some specific carb- kit info--
Carter BBD 8198S --- when engine has been run and is hot, and then parked, fuel begins to percolate and then we get a drip (once every 3-5 seconds) of fuel from the main throttle plate rod.....it comes out, runs along the spring and then drips....
Once the engine cools down it stops.
Carb was a new reman in package, still shrink wrapped rebuild from the 80s, and has run good, even now.....was installed maybe a year ago.
Upper body gaskets are looking soaked though.
Some good folks on the F body forum say its likely the float out of whack or dirt in the needle seat or maybe a hard seat. And that makes sense.....the carb, though "newly redone" was sitting for who knows how long.
SO I need a rebuild kit.
On rock auto they list a parts kit for the 80 Volare 2 bbl, but specify :
Fits2BBL; w/ Carter Carb.; w/ Mexico Emissions; BBD; 8314-8315
Or2BBL; w/ Carter Carb.; BBD; 8250, 8286-8287; w/ Canada or Export Emissions
So the query for all the slant 6 carb gurus here.....is this kit gonna work fine? Or keep looking?
Looking here http://www.carburetion.com/SiteCarbNumb ... and=Carter, it seems like they are the same kits and floats....but......want to be sure
Thanks all!
PostPosted: Fri Jul 27, 2018 9:02 am
8198s was for 1979 225 auto, federal emissions sedan weight class 3500 lbs and may be canada. In the us mid year running production change,8198s was replaced by 8264s . 1979 was last year for us bbd on cars for slantsix,still used in canada in 1980. Carter zip kit 902-325b 225 bbds 1977 -1980.
PostPosted: Fri Jul 27, 2018 9:57 am
Thanks! From what I can figure, looks like the kit we bought covers multiple years, including our 8198S.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 4 guests
