It is currently Mon Oct 19, 2026 6:48 am
PostPosted: Tue Sep 02, 2003 11:25 pm
Well I read a post and someone said they were having ballast resistor problems with their Mopar performance electric ignition.
So I looked into my Catalog and found 3 different resistors depending on ignition.
Point system- use P4529795
Electric ignition with 1/4 ohm coil - P2444641
Electric ignition with 1 ohm coil - P5206436
Basically i am using the last resistor since I am using an Accel Supercoil.
Also would like to plug www.kollerdodge.com for being one of the cheapest dealerships to get Mopar performance parts if of course you order online.
