It is currently Tue Nov 17, 2026 11:46 am
 Post subject: one ta two on the cheap
PostPosted: Tue Jan 08, 2019 3:08 pm
About ready to bolt on. About $285 invested so far. Carb has been rebuilt.
PostPosted: Tue Jan 08, 2019 5:17 pm
Very nice! Any more details, pictures?
PostPosted: Tue Jan 08, 2019 7:43 pm
Actually, the carb in pic 1 is sitting on the adaptor backwards, but who's counting. measuring the throttle bores, the 2 barrel is about 25% larger than the 1 barrel. Bridgeport work was a freebee from a friend who is a machinist. Set up was more time consuming than the actual cutting. I decided to go with aluminum because it is a little easier to work with / weld, and I could drop a little weight, and I had a chance to buy one in good shape for $75. Adapter was a 3/4" thick aluminum plate ( scrap ) from my local steel supplier ( $15 ). Carb was in good shape, but an unknown so I rebuilt it. I was originally going to bolt on the adapter, but I was talked in to having it welded on for - no leaks. It will be going on a stock 225 except for a slight CR mod - 7.8:1.
PostPosted: Tue Jan 08, 2019 7:54 pm
Car Model: 1975 Dodge D100
Super cool!
PostPosted: Wed Jan 09, 2019 1:23 pm
Car Model: 1982 D150
Nice work, looks very professional and clean.
Slant power!!!
At least I try...
PostPosted: Wed Jan 09, 2019 3:33 pm
Car Model: Toad Wagon
Yes, nice clean work.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sat Jan 19, 2019 12:19 pm
Some linkage pics. Used Lokar for the throttle linkage and Trans-Dapt for the kick-down linkage. Obviously had to fab up the brackets. Still cleaner than the factory stuff.
PostPosted: Sat Jan 19, 2019 5:29 pm
Very nice John!
PostPosted: Sun Jan 20, 2019 12:08 pm
Very nice John!
Thanks big D. Actually got it out a little yesterday. After some minor carb fuel needle and trans linkage adjustments, the little slant runs pretty good. Seat of the pants improvement at higher RPM's. Throttle pedal feel is slightly lighter than the factory, so I might add a return spring to go along with the carb spring. I did add a trans kick down lever return spring at the trans. Time for a 150 Nitrous shot!
PostPosted: Sun Jan 20, 2019 1:27 pm
Yes nice craftsmanship!
PostPosted: Sun Jan 20, 2019 5:13 pm
nice work!
A super six with the carb turned the right way.
:D :D
PostPosted: Thu Jan 24, 2019 10:41 am
That looks really nice!
Users browsing this forum: Bing [Bot] and 9 guests
