It is currently Fri Nov 13, 2026 10:03 pm
 Post subject: 9 1/4" rear ??
PostPosted: Wed Jan 16, 2019 4:53 am
I need to order C clips for Andrew Shanks W-100 with the 9 1/4" rear. On Summit they show 2 different thickness. Is there any way to tell what I have before taking them out? One is .175 thick the other is .205 thick. Also at 11.00 & $15.80 each it is a huge rip off! I may need to check with Chrysler, they may be cheaper there!
 Post subject: Re: 9 1/4" rear ??
PostPosted: Wed Jan 16, 2019 7:14 pm
Does rockauto have them ? (better price ? , no idea which one)
PostPosted: Thu Jan 17, 2019 3:18 am
Same price.
PostPosted: Thu Jan 17, 2019 8:55 am
That might seem high... but remember what they do. That is one critical part.
Good axle seals can be $8-$9. Just for some perspective.
Or you can go to junkyard and pull some for 5 nickels and try to talk the guy down to 2 nickels...
:D
PostPosted: Thu Jan 17, 2019 2:17 pm
Yep it is perspective. But Dorman has many different ones for $4-$5. Probably just about the same thing as I am looking for that costs $15 plus $6 shipping.
PostPosted: Thu Jan 17, 2019 4:18 pm
The thicker ones are probably for axles with the groove worn to save buying new axles.
PostPosted: Thu Jan 17, 2019 5:27 pm
Yes you may be right. I think I will buy them both and have them on hand when I pull the axles.
PostPosted: Fri Jan 18, 2019 2:44 am
If the rear is not apart, what makes you need new "C" clips?
PostPosted: Fri Jan 18, 2019 3:22 am
Not 100% sure Charlie, but Andrew's truck has a clunk when weight shifts side to side and I thought it may be wear on the Clips since that is all that is holding the axles in. I have not got it in my garage yet to look closely at it. May be that it is something else so I'll look closer before ordering.
PostPosted: Fri Jan 18, 2019 9:27 am
In all honesty, I have never seen the clips themselves wear. The groove widens in the axles. If it is in fact what is making the clunk, it's really axle time. :oops:
PostPosted: Fri Jan 18, 2019 9:30 am
Ok I'll just need to do a little more investigation! Thanks
PostPosted: Fri Jan 18, 2019 9:34 am
Definitely a time to disassemble before ordering. On a side note, the bearing adjusters on a 9-1/4" can be a real PITA to get back in and adjust without the tool. You can make one with a little ingenuity, or be lazy like me and order one off E-Bay for $45. :lol:
PostPosted: Fri Jan 18, 2019 4:20 pm
http://imperialclub.org/Repair/Lit/Films/368/
PostPosted: Fri Jan 18, 2019 5:58 pm
Thanks for that video! That may well be the problem.
