9 1/4" rear ??
https://slantsix.org/forum/viewtopic.php?t=63189
Author:  Rick Covalt [ Wed Jan 16, 2019 4:53 am ]
Post subject:  9 1/4" rear ??
I need to order C clips for Andrew Shanks W-100 with the 9 1/4" rear. On Summit they show 2 different thickness. Is there any way to tell what I have before taking them out? One is .175 thick the other is .205 thick. Also at 11.00 & $15.80 each it is a huge rip off! I may need to check with Chrysler, they may be cheaper there!
Thanks
Author:  emsvitil [ Wed Jan 16, 2019 7:14 pm ]
Post subject:  Re: 9 1/4" rear ??
Does rockauto have them ? (better price ? , no idea which one)
Author:  Rick Covalt [ Thu Jan 17, 2019 3:18 am ]
Same price.
Author:  Greg Ondayko [ Thu Jan 17, 2019 8:55 am ]
That might seem high... but remember what they do. That is one critical part.
Good axle seals can be $8-$9. Just for some perspective.
Or you can go to junkyard and pull some for 5 nickels and try to talk the guy down to 2 nickels...
:D
Author:  Rick Covalt [ Thu Jan 17, 2019 2:17 pm ]
Yep it is perspective. But Dorman has many different ones for $4-$5. Probably just about the same thing as I am looking for that costs $15 plus $6 shipping.
Author:  slantzilla [ Thu Jan 17, 2019 4:18 pm ]
The thicker ones are probably for axles with the groove worn to save buying new axles.
Author:  Rick Covalt [ Thu Jan 17, 2019 5:27 pm ]
Yes you may be right. I think I will buy them both and have them on hand when I pull the axles.
Author:  Charrlie_S [ Fri Jan 18, 2019 2:44 am ]
If the rear is not apart, what makes you need new "C" clips?
Author:  Rick Covalt [ Fri Jan 18, 2019 3:22 am ]
Not 100% sure Charlie, but Andrew's truck has a clunk when weight shifts side to side and I thought it may be wear on the Clips since that is all that is holding the axles in. I have not got it in my garage yet to look closely at it. May be that it is something else so I'll look closer before ordering.
Author:  slantzilla [ Fri Jan 18, 2019 9:27 am ]
In all honesty, I have never seen the clips themselves wear. The groove widens in the axles. If it is in fact what is making the clunk, it's really axle time. :oops:
Author:  Rick Covalt [ Fri Jan 18, 2019 9:30 am ]
Ok I'll just need to do a little more investigation! Thanks
Author:  slantzilla [ Fri Jan 18, 2019 9:34 am ]
Definitely a time to disassemble before ordering. On a side note, the bearing adjusters on a 9-1/4" can be a real PITA to get back in and adjust without the tool. You can make one with a little ingenuity, or be lazy like me and order one off E-Bay for $45. :lol:
Author:  matv91 [ Fri Jan 18, 2019 4:20 pm ]
http://imperialclub.org/Repair/Lit/Films/368/
Author:  Rick Covalt [ Fri Jan 18, 2019 5:58 pm ]
Thanks for that video! That may well be the problem.
