It is currently Tue Nov 17, 2026 9:53 am
PostPosted: Thu Jan 24, 2019 7:50 pm
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
I have a stock 77 D100 with a 225 and the stock alternator and I got my hands on an NOS giant 100 amp alternator. I know the 100 amp has three mounting points. Is there a special trick to mounting these to the Slant? I can't find any photos or references anywhere.
Thanks!
Chuck and the Flying Valiant
PostPosted: Fri Jan 25, 2019 7:44 am
Car Model: 1982 D150
If you find a way to mount it, you will have to beef up your charging system. Original wiring was not designed to support 100 amps.
Slant power!!!
At least I try...
PostPosted: Fri Jan 25, 2019 8:12 am
Yep. Already planning the voltage meter conversion and all that fun stuff. Just need to figure out how it was mounted. I know some Slant vans and trucks had them.
PostPosted: Fri Jan 25, 2019 10:12 am
Completely different brackets are used to mount the 100 amp alternator.
