| Mounting old giant 100 Amp Alternator to 77 D100 https://slantsix.org/forum/viewtopic.php?t=63215 |
| Author: | armyofchuckness [ Thu Jan 24, 2019 7:50 pm ] |
| Post subject: | Mounting old giant 100 Amp Alternator to 77 D100 |
I have a stock 77 D100 with a 225 and the stock alternator and I got my hands on an NOS giant 100 amp alternator. I know the 100 amp has three mounting points. Is there a special trick to mounting these to the Slant? I can't find any photos or references anywhere. Thanks! |
| Author: | enrique lopez [ Fri Jan 25, 2019 7:44 am ] |
| Post subject: | Re: Mounting old giant 100 Amp Alternator to 77 D100 |
If you find a way to mount it, you will have to beef up your charging system. Original wiring was not designed to support 100 amps. |
| Author: | armyofchuckness [ Fri Jan 25, 2019 8:12 am ] |
Yep. Already planning the voltage meter conversion and all that fun stuff. Just need to figure out how it was mounted. I know some Slant vans and trucks had them. |
| Author: | Joshie225 [ Fri Jan 25, 2019 10:12 am ] |
Completely different brackets are used to mount the 100 amp alternator. |
