It is currently Thu Nov 26, 2026 8:42 am
 Post subject: carb choices
PostPosted: Sat Jul 19, 2003 8:04 pm
I have a rebuilt 225 in my 72 duster, its got a mopar 460 lift cam, 6 into one header, lots of had work milled 0.050" oversized valves etc. And to top it off I've got the stock super six 2bbl on it. It runs real strong but I know it needs more carburation up top for the thirsty cam. I was just wondering what carb choices I have for a 4bbl intake. I just bought a used offenhauser intake with the adapter from a friend. What carbs fit this adapter? Which is the best choice overall for running on the street. Is the 390 holley 4bbl pretty much the best choice?
PostPosted: Sun Jul 20, 2003 12:49 am
Opinions are going to vary widely on this one, but I'm going to tell you that I ran both the 390cfm Holley on my mildly built /6 and a Carter AFB, and the AFB has been MUCH better, in terms of reliability, driveability and tune-ability. There is a 500cfm AFB available new, it may be a bit of overkill, but the air door on the secondaries is only going to allow the airflow you need anyway. I'm not sure what the smallest available flow is in the newly released AVS, but if there is a 500cfm version of it, I would enthusiastically recommend it.
Another option is to search Hemming's or other sources for an original Carter 4294S (there are a few other carb #'s that are the same basic carb, I'd have to research it for you) which is an approx. 400cfm AFB carb that originally came on a 273 V8.
I am biased and have never liked the Holley 4150/60 carburetors, the AFB is a much better carb for street/strip applications in my opinion.
"DW"
If it ain't broke, fix it!
PostPosted: Sun Jul 20, 2003 12:14 pm
This post rattled my memory and it dawned on me I have a 4294s buried in the garage,just didn't know the application. Odd thing is mine is setup to accept the earlier rod-operated throttle linkage complete with GM style choke although it was removed from a 64 Valiant /6! Naturally the ##** would not sell it with the manifold. This guy was heavy into Corvetts, so have a suspecion about the orgin of that GM choke. What do you expect for a $5.00 purchase....Dave
PostPosted: Sun Jul 20, 2003 2:22 pm
Sounds like a good deal to me. Oddly, I found mine through Hemming's at a Corvette specialty shop (somewhere in the mid-west) that had a mountain of old AFB's. I had to give $125, but it was complete and in good shape without too much throttle shaft wear. I generally won't give more than $40 for an old AFB, but my need was pretty acute and specific on this one.
I converted it to the later 5-1/8" air horn, mainly because of the super-six style air cleaner that I had converted to dual snorkel and already modified to fit the Holley, and the 5-1/8" is a lower profile for more hood clearance.
I was then able to sneakily use the old style 4-3/8" air horn from the 4294S on the Carter "Competition Series" 625cfm carb that goes on the "273" (ahem!) in my '65 Belvedere II :)
PostPosted: Sun Jul 20, 2003 2:53 pm
Pretty slick modification Dennis-mines not in too bad a shape, largest hurdle will be replacing all the missing linkage, but if it is true bolt on it will be worth it as I have the rod-operated throttle and saves me from having to convert to cable.,,,Dave
PostPosted: Sun Jul 20, 2003 10:18 pm
I don't know how your six is built, but you'll probably want to start with some way leaner jets on the secondaries than what came in the carb if they are still the same. I went by my old Direct Connection Engine book (I'm sure the latest MP edition has the same info in it) for a baseline on the jetting and went from there. I just solder up some jets and redrill them to get the small jet sizes.
"DW"
