| HELP! A904 throttle "kickdown" rods and linkages..what are they? SOLVED! https://slantsix.org/forum/viewtopic.php?t=63312 |
| Author: | TylerW [ Fri Feb 15, 2019 2:57 pm ] |
| Post subject: | HELP! A904 throttle "kickdown" rods and linkages..what are they? SOLVED! |
Hey guys: I'm going to edit this post, since I have solved my problem. I got confused about my throttle rod setup on my '68 and became convinced it was supposed to have some iteration of linkage and rod that it actually wasn't supposed to have because the manual I was referring to was WRONG. I finally recalled that I had downloaded the actual '68 Plymouth service manual and learned I have the proper parts after all. Feel free to watch the video if you want...there are a couple pictures at the end of older, more obsolete rods on there. https://www.youtube.com/watch?v=ELv9tkQ ... e=youtu.be |
| Author: | hank2 [ Fri Feb 15, 2019 11:37 pm ] |
| Post subject: | Re: HELP! A904 throttle "kickdown" rods and linkages..what are they? SOLVED! |
Glad that you got that figured out, Tyler. I just discovered your videos about a year or so ago and have enjoyed many of them. |
| Author: | DadTruck [ Sat Feb 16, 2019 7:56 am ] |
Quote: the manual I was referring to was WRONG.
where you using a Haynes Service manual?
