It is currently Tue Nov 17, 2026 10:34 am
 Post subject: Slant six cam question
PostPosted: Thu Apr 04, 2019 3:05 pm
Car Model: 1964 Dart 225/A833 3.55 9:1 CR .473 lift 500AVS
If I'm making a custom grind for my slant six, should I have more duration on the intake side and lift?versus the exhaust side, I'm running split manifolds into a y pipe. No header. Thanks let me know what you guys think.
PostPosted: Fri Apr 05, 2019 2:01 am
Yes, generally the 225 likes more intake duration than exhaust. It appears that 4-8 deg @ 0.050" more on the int is what works.
PostPosted: Fri Apr 05, 2019 11:33 am
Thanks Lou going to be putting a custom 268 .470 lift intake 264 .460 lift exhaust in my four speed
PostPosted: Fri Apr 05, 2019 1:02 pm
Sounds great. I would recommend 9:1 compression for that kind of cam. Can you list the duration at 0.050"? What are the other engine parameters (bigger valves, induction...)?
PostPosted: Sat Apr 06, 2019 3:37 pm
Yeah sure 230 236 @ 50, yes my motor is at 9:1 I'm currently running an Avs 500 cfm carb, the valves are stock but I have another head that I'm going to port out a bit and install some ford intake valves. I currently have the Howard's 256 .473 but she runs out of steam at 5k, I believe I under cammed my motor to my liking. I originally had 264 clifford 474 lift camshaft. I lost some top end for sure swapping almost 10 durations less. I mean the car is fast but I know with this new camshaft I'll be happy were I'm at. Hopefully lol. :mrgreen:
PostPosted: Sun Apr 07, 2019 6:18 am
For better power overall and a maybe bit less low end (and a bit rougher idle), set your lobe separation angle (LSA) to 106 deg. I do this for all my perf cams. Degree the cam at 100 installed centreline - best power overall AND better lower end than what most manufacturers recommend (104 or 108 or whatever).
A big valve head with even mild bowl porting will make a big difference over a stock head. Lots more top end, and no sacrifice in low end.
PostPosted: Sun Apr 07, 2019 10:38 pm
more power rougher idle! looks like 106LSA it is! sending the camshaft out tomo to get regrinded.
So Lou what do you think about the Howards 256 .473 lift camshaft i have? i feel like this is a RV Truck camshaft vs performance.
PostPosted: Mon Apr 08, 2019 2:57 am
It is hard to know how it (Howards Cam) will fare, performance-wise, until you get a good flowing head on the motor. Yes, I would say it is on the mild side and the LSA is large so bottom end and smoothness will be emphasized. I just bought one of those and will run it (sometime this summer) in an engine intended for supercharging. It will have a high flowing head on it. Will let you know how it feels.
Users browsing this forum: Google [Bot] and 9 guests
