It is currently Mon Nov 16, 2026 2:06 pm
 Post subject: Soluble oil
PostPosted: Tue Apr 09, 2019 12:09 am
Should I use soluble oil in my radiator - I have a slant 6 engine?
If soluble oil is suitable for use in the radiator/engine what quantity should I use?
 Post subject: Re: Soluble oil
PostPosted: Tue Apr 09, 2019 4:16 am
Car Model: '23 T-bucket
You mean, in addition to an ethylene glycol anti freeze? Why, and where did you hear this?
Roger
PostPosted: Tue Apr 09, 2019 4:58 am
Roger
Yeah, Why?
PostPosted: Tue Apr 09, 2019 4:59 am
Don't do it.
Years ago the owner of the company I worked for put soluble oil in the cooling system of his early 80s Cadillac. I guess he though it would lubricate the water pump and save him a few bucks by extending the life of the pump.
Well... it ruined all the hoses and cost him a bundle to have them all replaced. That Caddy was a nightmare under the hood and it was a big job.
--> The Diesel Corvette <--
PostPosted: Tue Apr 09, 2019 11:37 am
Very valid point. Not all "soft" under hood materials are oil resistant or proof.. It might take a month after addition, but they will deteriorate, leaving you with a possibly expensive mistake to correct.
Roger
PostPosted: Tue Apr 09, 2019 1:10 pm
Soluble oil is a product of the bad old days before permanent ethylene glycol coolants. Just don't go there. If you want to use it you might as well do a lube job and oil change every 1000 miles. Also discontinue use of seat belts, antibiotics, vaccines and anything else invented since WW2.
PostPosted: Sat May 04, 2019 9:22 pm
From my limited knowledge, soluble oil is a metal cutting coolant and lubricant, why on earth would you use this in your cooling system? it was designed for a completely different purpose.
b
https://tinyurl.com/yynpj4v2
Users browsing this forum: Ahrefs [Bot], Andrew Shank and 5 guests
