| Soluble oil https://slantsix.org/forum/viewtopic.php?t=63489 |
| Author: | crickhollow [ Tue Apr 09, 2019 12:09 am ] |
| Post subject: | Soluble oil |
Should I use soluble oil in my radiator - I have a slant 6 engine? If soluble oil is suitable for use in the radiator/engine what quantity should I use? |
| Author: | GTS225 [ Tue Apr 09, 2019 4:16 am ] |
| Post subject: | Re: Soluble oil |
Quote: Should I use soluble oil in my radiator - I have a slant 6 engine?
*******************************************************************If soluble oil is suitable for use in the radiator/engine what quantity should I use? You mean, in addition to an ethylene glycol anti freeze? Why, and where did you hear this? Roger |
| Author: | Charrlie_S [ Tue Apr 09, 2019 4:58 am ] |
Quote: Quote: Should I use soluble oil in my radiator - I have a slant 6 engine?
| Author: | ProCycle [ Tue Apr 09, 2019 4:59 am ] |
Don't do it.If soluble oil is suitable for use in the radiator/engine what quantity should I use? Years ago the owner of the company I worked for put soluble oil in the cooling system of his early 80s Cadillac. I guess he though it would lubricate the water pump and save him a few bucks by extending the life of the pump. Well... it ruined all the hoses and cost him a bundle to have them all replaced. That Caddy was a nightmare under the hood and it was a big job. |
| Author: | GTS225 [ Tue Apr 09, 2019 11:37 am ] |
Quote: Well... it ruined all the hoses and cost him a bundle to have them all replaced.
*******************************************************************************Very valid point. Not all "soft" under hood materials are oil resistant or proof.. It might take a month after addition, but they will deteriorate, leaving you with a possibly expensive mistake to correct. Roger |
| Author: | Joshie225 [ Tue Apr 09, 2019 1:10 pm ] |
Soluble oil is a product of the bad old days before permanent ethylene glycol coolants. Just don't go there. If you want to use it you might as well do a lube job and oil change every 1000 miles. Also discontinue use of seat belts, antibiotics, vaccines and anything else invented since WW2. |
| Author: | '67 Dart 270 [ Sat May 04, 2019 9:22 pm ] |
From my limited knowledge, soluble oil is a metal cutting coolant and lubricant, why on earth would you use this in your cooling system? it was designed for a completely different purpose. b |
