It is currently Fri Nov 20, 2026 1:19 am
PostPosted: Thu May 09, 2019 2:59 am
As many have announced before, the K1-Wiseco forged rod and piston combination leaves an above deck height of about 0.010-0.015.
Using a fixed number for combustion chamber volume of 58cc that leaves us with:
10.18 CR using an aussie gasket (compressed to 0.040).
9.98 CR using a 0.050 copper gasket.
My machinist said I shouldn't expect to be able to take more than a CC out of each combustion chamber by blending. Any more would end up trenching around the valve seats, causing turbulence in the valve flow.
That would get me -0.15 CR. Hypothetically.
How do I get the rest of the way for a CR of 8.5-9.0?
I run meth injection.
Double copper gasket? One flat and one with a fire ring?
Any proven combos that don't leak? (For a bit at least lol)
-Greg
What's this screw for?
'76 D100
PostPosted: Thu May 09, 2019 3:12 am
At one time, you could order copper gaskets that were as thick as about 0.120". That would about do it. Search for a company that can do that. Hussey and SCE are the two I remember. I have never used copper.
PostPosted: Thu May 09, 2019 12:40 pm
Ooh baby!
Thank the lord Hussey makes one in 0.120!
Leaves me at a nice 8.8 CR.
That is if I can actually get it to seal...
'76 D100
PostPosted: Sun May 12, 2019 2:34 am
Hi. Why don't you just machine the top of the pistons down to get were you want your CR? I have never measure how beefy the Wiseco are on top, but beein made of 4016 if you have at least 4.5mm left you should be OK.
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Fri Jun 07, 2019 7:08 am
Mine was .018-.020 in the hole not out if I remember correctly.
