Head Gaskets for Forged Turbo Motor
https://slantsix.org/forum/viewtopic.php?t=63601
Page 1 of 1
Author:  gtb123 [ Thu May 09, 2019 2:59 am ]
Post subject:  Head Gaskets for Forged Turbo Motor
As many have announced before, the K1-Wiseco forged rod and piston combination leaves an above deck height of about 0.010-0.015.
Using a fixed number for combustion chamber volume of 58cc that leaves us with:
10.18 CR using an aussie gasket (compressed to 0.040).
9.98 CR using a 0.050 copper gasket.
My machinist said I shouldn't expect to be able to take more than a CC out of each combustion chamber by blending. Any more would end up trenching around the valve seats, causing turbulence in the valve flow.
That would get me -0.15 CR. Hypothetically.
How do I get the rest of the way for a CR of 8.5-9.0?
I run meth injection.
Double copper gasket? One flat and one with a fire ring?
Any proven combos that don't leak? (For a bit at least lol)
-Greg
Author:  Dart270 [ Thu May 09, 2019 3:12 am ]
Post subject:  Re: Head Gaskets for Forged Turbo Motor
At one time, you could order copper gaskets that were as thick as about 0.120". That would about do it. Search for a company that can do that. Hussey and SCE are the two I remember. I have never used copper.
Author:  gtb123 [ Thu May 09, 2019 12:40 pm ]
Ooh baby!
Thank the lord Hussey makes one in 0.120!
Leaves me at a nice 8.8 CR.
That is if I can actually get it to seal...
Author:  Polara1974 [ Sun May 12, 2019 2:34 am ]
Hi. Why don't you just machine the top of the pistons down to get were you want your CR? I have never measure how beefy the Wiseco are on top, but beein made of 4016 if you have at least 4.5mm left you should be OK.
Author:  Rick Covalt [ Fri Jun 07, 2019 7:08 am ]
Mine was .018-.020 in the hole not out if I remember correctly.
