It is currently Thu Nov 26, 2026 5:07 pm
 Post subject: Thermostat housing
PostPosted: Fri Jul 25, 2003 12:12 am
Is the thermostat housing the same for all slants (or at least for all 225s)? I want to go to the wrecking yard and get a spare housing just so I have an extra since I'm going to drill and tap there to add the sender for the new temp gauge.
PostPosted: Fri Jul 25, 2003 6:05 am
It's the same at least for all car/truck Slants, and probably all others too. You can also use a mid-80's-up SB Mopar "straight out" neck by just drilling out the bolt holes to 3/8".
 Post subject: almost....
PostPosted: Fri Jul 25, 2003 7:07 am
They are all shaped the same, but I have a few earlier ones that are iron, the one on my Feather Duster is a cast pot aluminum, and some of the later replacements are some kind of chinese cheap pot metal...
My grandfather and I had to replace the pot metal one every time we changed the thermostat in my mom's valiant since they tended to crack, we switched to an iron one from his '65 Coronet and it was still going when we sold the car 8 years later...
good luck on the quest, and grab spares...
-D.idiot
PostPosted: Fri Jul 25, 2003 10:15 am
Check for porosity and cracks on those junkyard pieces. Just don't make my mistake and try to correct a poor sample by resurfacing to the point where they won't retain the thermostat! Got one so bad it sweats, saving this example for a future experiment. Next time i'll take along a small container of stripper so I can remove any paint/crud-gasket material and inspect them prior to purchase..Daah! live and learn...Dave
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 27 guests
