It is currently Sun Nov 15, 2026 1:28 pm
 Post subject: Dyno Day!
PostPosted: Tue Jul 02, 2019 9:33 pm
I decided to put my 1963 D100 with a stock slant six on the dyno. I thought y'all might enjoy the sound of it pounding out 55 furious ponies. :lol:
https://youtu.be/tISyUK7scpM
1963 D100: 3-on-the-tree, 3.50 rear, mostly original, stainless bore clutch slave & brake master, rebuilt speedo, original rebuilt carb.
1961 D200: crew cab short bed, sold.
1965 D500 Crew Cab, planning a 6V92 swap and 6x6 conversion.
 Post subject: Re: Dyno Day!
PostPosted: Tue Jul 02, 2019 11:37 pm
55 hp? That is pretty anemic. Is it a high mile motor?
PostPosted: Tue Jul 02, 2019 11:53 pm
Looks like it's running rich.
PostPosted: Wed Jul 03, 2019 4:52 am
55 horses might not sound like a lot, but I sure wouldn't want to clean up after them!
PostPosted: Wed Jul 03, 2019 5:37 am
Fifty-five horses are bound to kick something!
PostPosted: Wed Jul 03, 2019 5:51 am
Farmtruck states has a flat cam lobe.
PostPosted: Wed Jul 03, 2019 7:39 am
Car Model: '64 Valiant Convertible
The smoke ring after the first run-up was amazing! Never seen anything like it.
PostPosted: Wed Jul 03, 2019 7:57 am
I noticed the video is 2:25 long. :lol:
Escape Velocity Racing
PostPosted: Wed Jul 03, 2019 11:01 am
It's all original, sucking air through the oil-bath filter and untouched carb. And has one intake lobe worn to a circle. Given the condition, I wasn't expecting much more. What's hilarious is how little hp it made at higher RPM, it was down to about 32hp by 4000RPM. It made that 55hp at a mere 2700RPM, peak torque was 117@1600. :mrgreen:
PostPosted: Wed Jul 03, 2019 11:09 am
HAHA! I didn't notice that till you mentioned it. What a happy accident. :lol:
PostPosted: Wed Jul 03, 2019 12:01 pm
Well, that explains it. At least you can say you can easily double the output of your engine and have it still be naturally aspirated.
PostPosted: Fri Jul 05, 2019 12:03 am
Car Model: 1964 Valiant
My '61 D100 appears to be original too, except the intake and exhaust manifolds are from the '70s. At least your truck moves on its own power! I'm getting there - slowly. I expect everything will be slow with this truck.
PostPosted: Mon Jul 08, 2019 10:14 pm
Having owned a 1973 D100 with a dead cylinder (burned exhaust valve) I can relate to the dismal power output. 55-60 MPH is not a great top speed. I should dyno my '54 Dodge pickup and see how close it gets to the 123 gross hp printed on the tag.
PostPosted: Tue Jul 09, 2019 4:08 am
Car Model: '23 T-bucket
Josh, you could do that, but keep in mind what was posted is on a chassis dyno, not an engine dyno.
I suggest still not too bad for a half-worn-out, 60's farm truck.
Roger
PostPosted: Tue Jul 09, 2019 11:09 am
Roger,
I'm aware.
My 1954 C1 truck's ID tag states 145 certified gross hp and 123 certified net hp. I'm curious to know how much of that net hp makes it to the rear wheels. A highly reliable source states that 88% minus about 10hp should make it to the rear wheels. People claiming 30% drivetrain loss practice a foolish numbers game and will grossly over state the horsepower consumed by the engine accessories to support big engine horsepower numbers. The history of Dynojet's correction factor is telling.
Part of my interest in this is that the numbers for my 241 ci V8 are pretty close to the numbers given for an early 225 as was discussed in the cooling fan thread. http://slantsix.org/forum/viewtopic.php ... al#p457499
