It is currently Thu Nov 26, 2026 11:09 pm
PostPosted: Wed Jul 30, 2003 11:21 am
My engine is in the car stripped to the block. The pistons have a decent amount of hard carbon deposits on the crowns as well as some in the combustion chamber part of the cylinders. I'd like to clean this up a bit but dont want to gouge the metal or let a bunch of solvent seep into the oil pan. Anybody know how I can get this accomplished?? Thanks.
PostPosted: Wed Jul 30, 2003 11:38 am
Protect surrounding areas with rags, etc, then break out a cup-style wire brush on your drill motor. Bring the pistons up to Top Dead Center two at a time and do them there. Use compressed air if equipped to blow out around the top of the piston when you are through with each. A little carbon dust is not going to hurt anything... An errant wire from the brush might, so clean up the best you can. Same goes for the head.
"DW"
If it ain't broke, fix it!
PostPosted: Wed Jul 30, 2003 11:51 am
I would be very careful about removing chunks of carbon, as they can be very hard (with motor metal combined) and can get down between the piston and wall. I have seen a few motors with cyl wall gouges after such cleaning.
That said, I have carefully removed some piston carbon using a rag, followed by vacuuming the carbon chunks/dust. After that, I moved the pistons down to the bottom of the bore, vacuumed and cleaned the cyl walls with a slightly oiled (clean) rag, then repeated this a couple of times for each piston until the chunks did not appear on the wall.
Cheers,
Users browsing this forum: Bing [Bot], Google [Bot] and 28 guests
