It is currently Mon Apr 20, 2026 4:29 pm
PostPosted: Sun Sep 29, 2019 7:29 pm
1965 Valiant
Ten years after a transmission rebuild I finally undertook to address a hard 1-2 shift at slow speed / light throttle.
The thing worked fine but on soft acceleration from dead stop it would always shift with a hard clunk.
There is a threaded rod that attaches to the carb linkage and goes down to the trans, co-ordinates the throttle position with the trans fluid pressure & shift points. Apply some liquid wrench to the threads and simply pull / pop out the ball from the socket ( held in by a spring clip). Other years & set ups use a cable vs a threaded ride; not sure how the cable adjust but result should be the same.
-If the trans seems to up-shift slow & harsh there is probably too much pressure ; shorten the linkage ....a little goes a long ways.
I did three turns of the buckle and it was perfect... vast improvement. Still a firm shift but not a jarring clunk. Don't make it too short , to the point where the shift is too soft and you are slipping & chewing up bands
-If the trans up-shift is too fast, there may not be enough pressure on the kick down lever, you may need to lengthen the linkage.
Imagine... after 10 years; 20 minutes of web search and 10 minutes of shade tree mechanic work time; short test ride and it was Miller Time !
