| 904 / 727 automatic transmission harsh or soft shift https://slantsix.org/forum/viewtopic.php?t=64104 |
| Author: | steve93101 [ Sun Sep 29, 2019 7:29 pm ] |
| Post subject: | 904 / 727 automatic transmission harsh or soft shift |
1965 Valiant Ten years after a transmission rebuild I finally undertook to address a hard 1-2 shift at slow speed / light throttle. The thing worked fine but on soft acceleration from dead stop it would always shift with a hard clunk. There is a threaded rod that attaches to the carb linkage and goes down to the trans, co-ordinates the throttle position with the trans fluid pressure & shift points. Apply some liquid wrench to the threads and simply pull / pop out the ball from the socket ( held in by a spring clip). Other years & set ups use a cable vs a threaded ride; not sure how the cable adjust but result should be the same. -If the trans seems to up-shift slow & harsh there is probably too much pressure ; shorten the linkage ....a little goes a long ways. I did three turns of the buckle and it was perfect... vast improvement. Still a firm shift but not a jarring clunk. Don't make it too short , to the point where the shift is too soft and you are slipping & chewing up bands -If the trans up-shift is too fast, there may not be enough pressure on the kick down lever, you may need to lengthen the linkage. Imagine... after 10 years; 20 minutes of web search and 10 minutes of shade tree mechanic work time; short test ride and it was Miller Time !
