It is currently Fri Nov 27, 2026 8:59 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Tue Oct 01, 2019 2:23 pm
Car Model: 1980 Chrysler lebaron 3.7l 225ci
So I was driving it in my apt and all of a sudden on acceleration I hear knocking. So I parked it but it sounds like a pushrod or a lifter. It still start and runs , on idle you don't hear it unless you hit the gas any ideas on what it can be?
PostPosted: Tue Oct 01, 2019 2:40 pm
Car Model: '23 T-bucket
I assume it's a Lebaron, as shown in your profile?
What was the last gas that you put into it? If it's crappy gas, might it be a bit of detonation, or pinging?
Roger
PostPosted: Tue Oct 01, 2019 2:53 pm
[quote="GTS225"]I assume it's a Lebaron, as shown in your profile?
Yes it is got her running and just regular gas do I need something and I'm going to post it on
PostPosted: Tue Oct 01, 2019 3:03 pm
Video on YouTube search:
1980 Chrysler lebaron slant6 knocking any ideas
PostPosted: Tue Oct 01, 2019 3:08 pm
Roger
No pinging just knock on acceleration and idk if it detonating
PostPosted: Wed Oct 02, 2019 9:53 am
https://youtu.be/o1nT_0y-Ssk
PostPosted: Wed Oct 02, 2019 2:07 pm
#1 That sounds like a rod knock. Sorry.
#2 You cannot check the oil level with the engine running as oil is flying around and wetting the dipstick. The engine should be off for a minute or so to allow the oil to drain into the pan for an accurate reading.
PostPosted: Wed Oct 02, 2019 2:19 pm
Where are you in Houston? I have a similar vintage cast-crank short block in the vicinity of Hobby Airport, which you can have for free if you come get it. Condition unknown, but it does turn over. Send me a PM if you're interested.
Escape Velocity Racing
PostPosted: Wed Oct 02, 2019 5:36 pm
Online
Site Admin
Might check the Converter bolts first.
CJ
PostPosted: Wed Oct 02, 2019 7:41 pm
Car Model: '64 Valiant Convertible
When I was in High School, the shop instructor used plastic pliers to individually (1 at a time) pull plug wires from an engine running at idle that was knocking. When he got to the cylinder with the bad rod, the knock went away.
Anyone else tried or had success identifying a bad rod this way?
PostPosted: Wed Oct 02, 2019 9:27 pm
I was hoping not but I'm going to take spacefrank up on his offer really want to give the eagle the chance to live again but
PostPosted: Wed Oct 02, 2019 9:34 pm
CJ
Could be cause when I first got her running I put in reverse and the eagle wouldn't move so I put in drive it moved ,so then I put it in reverse and it moved sluggish but did then I realized it only moves really when the idle is smooth but that's only when it's in gear so little confused on that?
PostPosted: Wed Oct 02, 2019 9:36 pm
I kind of don't believe it cause I pulled wires where the sound is #1 and #2 area no sound change no nothing but I have tried
PostPosted: Thu Oct 03, 2019 7:39 pm
The sound in the video is exactly how a rod knock sounds.
A loose converter bolt has a higher repetition to the clatter as it will sound
with every revolution of the crankshaft. Every time the protruding bolt passes by
the rear block flange it will hit and make a clatter.
A bad rod bearing usually only sounds out on the down stroke of the
combustion cycle. Every other crank shaft revolution, a rod bearing knock
also sounds ‘hollow’ exactly like the sound in the video.
PostPosted: Thu Oct 03, 2019 8:25 pm
you sure can be the timing chain only thing I haven't touch and it rattles a lil bit when starting up and dies when you put in gear
