It is currently Fri Nov 27, 2026 5:20 am
 Post subject: oil pump holes..5 or 6
PostPosted: Sun Aug 03, 2003 8:44 am
I am replacing the oil pump on my Slant Six (1974). I was able to locate a NOS oil pump from a dealer here in Calif. The NOS has 5 holes whereas the original pump 6 holes. I have read it is okay to use the 5 hole pump without any trouble. Comments appreciated...
PostPosted: Sun Aug 03, 2003 11:46 am
I think Doc was trying to put together a list of the years/vehicles that got the six hole pump vs the 5 hole pump. My '87 truck's original pump had 5, the hi-vol pump I ordered from the dealership only had 5 holes drilled, but there was a bung to drill a 6th. My block only has provisions for 5 holes.
At any rate, you will be fine using the 5-hole pump. ( I believe the sixth was eliminated because it was determined to not be necessary)
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Sun Aug 03, 2003 8:13 pm
The 6 hole pump seems to have ended around '76 or so. The 5 hole pumps have a thicker rotor in them. :shock:
PostPosted: Sun Aug 03, 2003 10:07 pm
Rotor thickness is related to the number of holes,
6 hole pumps have the 5/8 thick rotor, 5 hole pumps have the thicker 7/8 rotor.
Either one works fine as long as the gear holds-up. :shock:
Users browsing this forum: Ahrefs [Bot] and 7 guests
