It is currently Mon Jun 22, 2026 10:28 am
 Post subject: external oil lines?
PostPosted: Mon Feb 17, 2020 1:24 pm
This is to all the guys running external oil pumps and/or remote filter mounts on their slants.
What size hose would be recommended for this? I am considering -10AN, but I also have some-8AN that would be easier to route in tight bends.
Mine will be to a remote filter mount.
 Post subject: Re: external oil lines?
PostPosted: Mon Feb 17, 2020 2:42 pm
Fro an oil filter In/Out? I'd use #10. No way #6.
PostPosted: Mon Feb 17, 2020 3:00 pm
Sorry, that was a typo on my part. I meant to say -10AN or -8AN.
Yeah, -6 would be askin for trouble.
PostPosted: Tue Feb 18, 2020 2:32 am
I have -10 on my race setup.
PostPosted: Tue Feb 18, 2020 4:38 am
It's worth noting that the early Slants that use the oil standpipe are necked down to under a #6 size, oddly enough. So while I would never do it, if you did use #6 you wouldn't be completely off base.
PostPosted: Tue Feb 18, 2020 5:03 am
-6AN was a typo on my part. My choices are either -8AN or -10AN. The #10 looks more 'comfortable' to me so I will likely go with that, but the #8 would bend tighter without kinking. Anyway, I was just wondering what sizes you guys used on your cars.
PostPosted: Tue Feb 18, 2020 8:24 am
I experienced high (5000+) RPM oil pressure fall off with a standpipe-equipped oil pump. I replaced the stand pipe with the simple joint and the oil pressure problem went away. I will not be running a standpipe on any of my performance motors again.
PostPosted: Tue Feb 18, 2020 8:28 am
I'm not surprised. It's a tiny hole! I used a standpipe but I made one with a much larger minimum diameter.
PostPosted: Tue Feb 18, 2020 9:59 am
Car Model: Toad Wagon
Like Lou, I also had the stock standpipe flow problem. The SUs I run'll happily pass 7 grand when I'm inattentive, and it cost me a couple sets of bearings on my HAMBster before I figured it out (yeah, I can be a slow learner at times). I stopped running one on my daily as well, as on "rare occasion" I've been known to press the pedal a skosh above the need. :roll:
Eventually I cobbled up a couple standpipe bases with larger pipe welded on, then drilled through. Those're both still in service.
Upshot; if going AN I think I agree with you, I'd stick to ten.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Feb 20, 2020 9:08 am
As a "fine point", the factory "stand pipe" assembly is actually a check-valve / standpipe combination and yes, it is pretty restrictive thru the valve.
Like others, I have used a large diameter standpipe tube, with-out a check valve and had good results.
( no high RPM oil pressure drop-off and reduced oil filter drain-back)
PostPosted: Thu Feb 20, 2020 9:38 am
Where is the check valve? Mine didn't have one....maybe someone tossed it.
PostPosted: Thu Feb 20, 2020 9:28 pm
DD is totally on point. I use the short pipe adapter with a filter that has a standpipe, but even then I bored the adapter hole out as it was pretty narrow. That all said, I don't take mine to 5000 rpms.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Fri Feb 21, 2020 6:31 am
http://www.slantsix.org/forum/viewtopic ... e&start=15
