Mark Four turbo build thread
https://slantsix.org/forum/viewtopic.php?t=64567
Page 1 of 2
Author:  MadScientistMatt [ Mon Mar 02, 2020 9:52 am ]
Post subject:  Mark Four turbo build thread
Although this is the fourth turbo combination I've run, it's my first engine rebuild. Thanks to coconuteater and Charlie S for donating several parts, and also to the others who'd offered to help. Today this build got started with dropping the parts off at the machine shop. One BH code block:
File comment: One BH-code block
And two small torque converter cranks:
File comment: Two small torque converter cranks
Author:  Greg Ondayko [ Mon Mar 02, 2020 11:59 am ]
Post subject:  Re: Mark Four turbo build thread
Matt, I would Highly recommend the Oiling system mods Doc Proposes in this document.
http://www.slantsix.org/articles/dutra- ... blocks.htm
Happy building and boosting. - with the Power and tunability ( ability to make more power) that you will infuse onto the slant you will want those parts to be skookum as frig!
Happy Building and Boosting!
Author:  MadScientistMatt [ Thu Mar 19, 2020 8:42 am ]
No progress this week as I'm working from home and the car's at the shop at work. But last week I got a few pictures of doing Doc's water pump block mod. I know, should have done that before taking it to the machine shop, but better late than never!
This block had a big ridge in the water pump cavity.
Let's make some sparks.
The final result.
Author:  MadScientistMatt [ Mon Mar 30, 2020 1:26 pm ]
I tried to use some grease to keep debris out of the oil galley while doing Doc's oil galley porting mod.
It did not work quite as I had hoped.
Author:  Dart270 [ Mon Mar 30, 2020 2:08 pm ]
Ouch. I always take some time and do all my grinding and dirty prep before I take the engine to the shop to get cleaned up and machined. You can do grinding afterwards before assembly, but it's a pain to clean everything...
Author:  Greg Ondayko [ Mon Mar 30, 2020 5:55 pm ]
Blast that clean with brake cleaner and pipe brushes before assembly!
Author:  MadScientistMatt [ Tue Mar 31, 2020 7:26 am ]
No, it's not blood. Just looks like it. :)
Already hosed it down with brake cleaner, will try cleaning it with a gun cleaning patch as well before starting.
Author:  DadTruck [ Sun Apr 05, 2020 7:33 pm ]
Matt, did you get that painted red block from Cocanuteater?
If so I think I recognize it as one of the slants that he picked up from me in Indy.
He drove up from GA to get it.
If it is the same motor, I pulled it from a rusted beyond repair D150 that was headed for the crusher.
That may have been in 2010, or so.
Always good to see a motor that was saved going to good use.
One more thing,,IIRC, that slant was in front of a a833 od transmission, so the crank is drilled / sized for a pilot bushing, there should be one in it,,
But that has been along time ago and I could have it wrong,,
Author:  DadTruck [ Sun Apr 05, 2020 7:34 pm ]
One more thing,,IIRC, that slant was in front of a a833 od transmission, so the crank is drilled / sized for a pilot bushing, there should be a pilot bushing in it,,
Author:  MadScientistMatt [ Mon Apr 06, 2020 5:09 am ]
Yes, I picked up the block (and rods) from Coconuteater. But it's being paired with a small torque converter flange crank so I can keep my current transmission.
It turns out the block had already been bored 0.030" over. But the pistons had some seriously weird damage to their tops - maybe detonation pitting, but it looked like they'd been damaged by something else. I could almost have done a hone and reuse job if I'd trusted the pistons not to crack, but instead I decided to have the block taken to 0.040" oversized.
Author:  DadTruck [ Mon Apr 06, 2020 10:50 am ]
There was a teen age boy hanging around the area, I gave him a few bucks to help me pull
the motor. He had already hot wired the engine and had a fuel supply rigged out of a pop bottle and had started the motor a few times. I had heard it run. The carb was open with no air filter or housing so it easily could have ingested something..
Interesting find on the block being overbore, the engine was a combination of non matched parts.
Head was blue, the block red, oil pan black,,,, but I knew it ran,,,
And now it will run again,,that is great!
Author:  Dart270 [ Mon Apr 06, 2020 11:46 am ]
Strongly suggest boring to 0.060" over.
Author:  DadTruck [ Mon Apr 06, 2020 11:49 am ]
Agree, the .060 over bore is enough to actually de shroud the valves,
Although anything helps.
Author:  MadScientistMatt [ Tue Apr 07, 2020 12:22 pm ]
Unfortunately, I've already got the pistons and the machine work done. This will let me save the 0.060" overbore if I end up with a Mark Five built with custom forged pistons and 198 rods, though. :) I'm a bit surprised that a 0.010" difference between the valve and cylinder wall would change flow so much; my thinking was that a little extra wall thickness would help with ring seal.
I am using stock valves but plan to do a bit of bowl work and a 3-angle valve job on the head before re-installing it.
Author:  DadTruck [ Tue Apr 07, 2020 5:05 pm ]
just going .020 over probably helps, so .040 over helps more,, .060 a little more
David Vizard has a clearance where the bore no longer influences the air flow,,
I will see if I can find that.
Page 1 of 2 All times are UTC-08:00
