It is currently Tue Nov 17, 2026 9:41 pm
 Post subject: Engine not catching
PostPosted: Wed Apr 01, 2020 7:39 pm
Car Model: 1962 Dodge Dart
Hi all,
I have been puzzling with my motor on and off for a couple weeks. I am hoping to get some insights as to why my motor would not continue running once I release the "start" switch. I get a steady ignition noise (the sound of pistons firing and the engine gets warm), but once I release the "start" position the engine dies. I just measured the power coming from the top of the coil (as it would go to the distributor) and it reads 1.32 when set to the 20k DC setting. If I let it sit it starts to drop, quickly at first then slows, all the way down to 0.82 after ten minutes. I think it would keep dropping but stopped there.
Not sure if that description helps.
Any insights as to why it won't stay running? The engine is out of the car and mounted to a pallet if that helps at all.
Sincerely,
Paul
 Post subject: Re: Engine not catching
PostPosted: Wed Apr 01, 2020 7:47 pm
It would be helpful if you would sketch out a drawing detailing how you have the engine / test stand wired.
PostPosted: Wed Apr 01, 2020 11:29 pm
Trace the "RUN" wire back to the bulkhead connector and check the contacts in the connector. It will probably be a blue wire. Check the ballast resistor for continuity too.
PostPosted: Thu Apr 02, 2020 11:22 am
Our 74 & 75's have a "start-run" relay near the ballast resistor. That relay has shut us down several times, mostly due to dirty contacts inside.
PostPosted: Thu Apr 02, 2020 2:36 pm
Dual ballast resistor? Sometimes the run side burns out.
PostPosted: Thu Apr 02, 2020 7:46 pm
I will try and sketch out my wiring diagram tomorrow and will upload the picture.
Paul
PostPosted: Sun Apr 05, 2020 2:09 pm
Hi all,
Below is my diagram. I hope it is clear enough to make sense of. Looking at everything as I drew this I wonder if I got the solenoid and ignition to resistor wires switched.
Sincerely,
Paul Barrow
PostPosted: Sun Apr 05, 2020 3:58 pm
You cannot have the starter solenoid connected to the ballast resistor. The solenoid will steal energy meant for the coil. Chrysler ignition switches have Ign 1, Ign 2 and start terminals because you need all of them. Delete the wire between the solenoid and the ballast resistor. A ballast resistor bypass will require more parts. A relay triggered by the solenoid wire being one method.
PostPosted: Sun Apr 05, 2020 6:30 pm
that solenoid to ballast wire is just the full 12v "kick"/ "ballast bypass during start" I wouldn't think the ignition would bleed that much, from the starter solenoid's function.....
PostPosted: Sun Apr 05, 2020 10:43 pm
What's your wager?
PostPosted: Mon Apr 06, 2020 6:26 am
Thanks guys,
I suppose one question to ask would be is there any way I could wire this incorrectly that would cause damage? If not, I will try your suggestion tonight Joshie.
Thanks again,
Paul
PostPosted: Mon Apr 06, 2020 9:53 am
Since it seems to want to fire while cranking, I wouldn't think the start circuit is the problem.
You say that it dies when the key is released to the run position so I would look at that part of the circuit, especially the ballast itself.
What is the voltage at the coil with the key in the run position?
You might try bypassing the ballast temporarily as an experiment.
By the way, nice job on the schematic 8)
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Mon Apr 06, 2020 10:13 am
If he bypasses the ballast resistor without making other changes to his wiring the starter will engage when the ignition switch is on. The interconnection between the starter solenoid and the ignition must be removed.
PostPosted: Mon Apr 06, 2020 10:17 am
True - hence your point about properly wiring the bypass.
A temporary 'run' bypass is usually considered 'hot-wiring', such as a wire straight from B+ to the coil.
I'm sorry for not more clearly making the connection :lol: :wink:
O==\=/==O
- Jim Preston
PostPosted: Mon Apr 06, 2020 10:32 am
Yeah didn't think about that.
I'm thinking of the old 4 pin ballast and 5 pin ecu,not the 2 pin ballast and 4pin ecu. I was thinking if he went off of the same terminal from the starter relay that the small wire on the starter solenoid is wired from that it would be a safe way to go but maybe not
Users browsing this forum: Google [Bot] and 8 guests
