It is currently Sun Oct 25, 2026 2:11 pm
 Post subject: To mill or not to mill
PostPosted: Thu Aug 07, 2003 10:53 pm
I'm gonna do an intake/exhaust upgrade soon and was wondering a few things- :?
1. Someone said I should have the head milled (just a surfacing), while I have the intakes off. Is this worth the extra labor?
2. I have a '64 and it has the spark plug tubes. I think they are leaking right now. Can I get replacement o rings or should I get a newer head that doesn't have them?
3. If I get the head milled, how much do I have to mess with the valves (take them out, change springs)? Do I need special tools for this?
4. Anything else concerning the head I'm forgeting?
Thanks for all y'alls input ! :P
"Nothing in all creation is hidden from God's sight. Everything is uncovered and laid bare before the eyes of Him to whom we must give account."
 Post subject: How many miles?
PostPosted: Thu Aug 07, 2003 11:04 pm
If the head is original to your engine you shouldn't have to plane it unless the deck and head are way out of spec. (need a machinists straight edge and drag a long feeler gauge through in spots to check the 'warp'.
If your head has never had the guides serviced and/or is a high miler motor, you may find one or more guides to be 'worn' and need replacing.
If you have to have the head rebuilt, now would be a good time to get that port job you've always wanted and use your upgrades better.
If you feel you need a 'BL' style head, and can't find a good one locally let me know I have one with a 1 year old valve job sitting in my garage. Shipping might be attrocious, but it'd make a good start, and I could use the $$$ more than the head.
PostPosted: Thu Aug 07, 2003 11:14 pm
Spark plug tube seals are availible. Use some sicky RTV around them when you put them back in.
PostPosted: Thu Aug 07, 2003 11:20 pm
I've always wondered if the O-rings on the spark plug tubes did anything special. Do they really have a purpose or are they just there to hold the tube against the head?
PostPosted: Fri Aug 08, 2003 12:19 am
It is an oil seal... the oil from the valve train (and when you poor oil in your engine via valvecover opening) can splosh out of there otherwise. Leave take one off for a while and see how quick it'll start leaking ;)
Users browsing this forum: Google [Bot] and 14 guests
