It is currently Tue Nov 17, 2026 1:52 am
PostPosted: Sun May 03, 2020 8:57 am
Car Model: 1974 Duster
Just got a '74 Duster with the slant six / A-904 automatic. If I swap in a rebuilt 360, will the transmission bolt up, or will I need to find a different one for the V8? Thanks.
Deniel
my review - https://ballisticparts.com/general-grab ... -problems/
PostPosted: Sun May 03, 2020 9:05 am
No. Mopar small block, big block, and slants each have unique bell housing bolt patterns.
PostPosted: Sun May 03, 2020 9:25 am
Sure! You just have to take out cylinders 5&7 to clear the starter. 8)
PostPosted: Sun May 03, 2020 6:49 pm
Car Model: '23 T-bucket
You will also need a 360 specific torque converter. The 360 is externally balanced by weights on the converter, while the 318 and 340 is internally balanced
Roger
PostPosted: Sun May 03, 2020 9:01 pm
And just wondering will the slant six 904 handle the extra toque and HP of the 360? As well as the rear end?
PostPosted: Sun May 03, 2020 9:13 pm
This is a moot point because the slant six 904 will not bolt to the 360. You will need to get a small block 904. The small block 904s have stronger internal components than the slant six 904s.
PostPosted: Mon May 04, 2020 8:16 pm
I suspected something like that to be true.
PostPosted: Tue May 05, 2020 6:11 am
HAHAHA HAHAHA
PostPosted: Tue May 05, 2020 9:33 am
I have a 904 behind a 340. The guts were out of one of my Slant race trans. Those guts were out of a small block 904. :lol: :lol: :lol:
PostPosted: Tue May 05, 2020 9:43 am
I should have been clearer: "IN STOCK FORM the small block 904s have stronger internal components than the slant six 904s."
PostPosted: Wed May 06, 2020 7:17 am
Your point was clear, and now its even clearer. :D
PostPosted: Fri May 08, 2020 1:42 pm
Won't fit, won't handle it, and that goes for both,...........
PostPosted: Fri May 08, 2020 10:48 pm
Does your car have disk brakes or drum? What rearend does it have? What size radiator? Do you have a V8 k-member?
PostPosted: Thu May 21, 2020 5:59 pm
Car Model: 62 Valiant
looking at a V8 and Slant 6 crossmember from a 64 valiant last year, I couldnt see any differences. the slant mounts would bolt right into the v8 crossmember but for the slightest misalignment. is there a difference? is only some years?
PostPosted: Thu May 21, 2020 6:14 pm
64-66 only used one K-member as far as engine mounting is concerned. You can swap from a Slant to a V-8 by changing motor mounts and brackets (and drag link).
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
