It is currently Mon Nov 16, 2026 12:28 pm
 Post subject: Carb ID please
PostPosted: Mon Jun 01, 2020 12:38 pm
Car Model: 65 dart hopefully
Hello Everyone
Could I get some help identifying this carb and how to adjust it
Not sure of what I have
Running on a 1971 Dodge D100 sweptline
225
https://app.photobucket.com/u/mas3fish/ ... c16c0a0d41
Thanks for any Help
 Post subject: Re: Carb ID please
PostPosted: Mon Jun 01, 2020 12:42 pm
Looks like a Carter BBS 1 bbl. What would you like to adjust? I am not an expert on that carb, but there should be others on here who are.
PostPosted: Mon Jun 01, 2020 1:40 pm
I felt it was a 1 barrel
I have 2 adjustment screws I believe fast idle and curb idle
Need a guide to get it close
I got the timing nailed and all other systems working
I even thing I got the choke unstuck
Just trying to dial it in
PostPosted: Mon Jun 01, 2020 2:50 pm
http://www.slantsix.org/forum/viewtopic.php?t=55801 Go to that page get bbs manual. The outside screw that buts up to big screw is curb idle. The inside screw that lines up with notched move able piece is fast idle choke on. That is 1970-71 carb, has hot idle valve, tin cover with 2 screws.
PostPosted: Mon Jun 01, 2020 2:54 pm
There should be a 3rd adjustment screw, for idle mixture down low by the throttle butterfly
PostPosted: Mon Jun 01, 2020 6:27 pm
Yes, it's a Carter BBS. They are not all alike, and parts store kit quality is pathetic these days.
Yours (in the pic) needs repair. The bowl vent stem washer has pulled out of the airhorn casting and needs to be staked back in place. Order a kit № 2151 from The Carburetor Shop in Missouri. Kits don't come with a proper float gauge any more, all you get is a useless strip-of-paper pretend ruler. That makes problems because setting the float height is a crucial part of rebuilding a carburetor (float wear is not likely, but the float must be checked to make sure gasoline hasn't got inside and made the float heavy). The Carburetor Shop sells gauges separately—the factory metal ones; don't know how much they charge. One workaround is to also buy an old-stock kit off eBay and rob the float gauge out of it. Another workaround is here.
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. Also look at the tune-up parts and technique suggestions in this post (how long since this engine has had a valve adjustment?).
PostPosted: Tue Jun 02, 2020 4:30 am
Thanks for all the advice
I will buy the kit and start working on it.
I bought the truck in Feb 2020 pulled it out of a field and got it running over the winter.
It definitely needs a valve adjustment as well as a new valve cover gasket.
thanks
Mike
Users browsing this forum: Ahrefs [Bot] and 7 guests
