It is currently Mon Nov 16, 2026 4:45 pm
PostPosted: Sat Jun 20, 2020 10:24 pm
Car Model: 1965 Dodge A100 Pickup w/Super Six
I am rebuilding a 1965 /6 225 engine to replace my 74 /6 that is in my truck. The mechanical oil gauge hasn't worked in the five years that I have had the vehicle. The engine on the stand has a npt fitting left of the oil pump which I would access, but the engine in the car, which I would like to access now, has no fitting there. Where would there be a good place to hook up this fitting, and activate my oil pressure gauge for the first time. Thanks...............Gary
PostPosted: Sun Jun 21, 2020 5:36 am
Under the oil filter, on the oil pump, there should be a factory oil pressure sender. Either remove this and replace it with the mechanical sender fitting, or place a 'T' in that spot to use both.
PostPosted: Sat Jun 27, 2020 10:12 am
The tapped hole in the rear of the main oil galley is a great place to install an oil pressure gauge fitting or sending unit.
Many are not tapped so I drill and tap this location when rebuilding an engine.
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
