| Mechanical oil pressure gauge https://slantsix.org/forum/viewtopic.php?t=65028 |
| Author: | a100gary [ Sat Jun 20, 2020 10:24 pm ] |
| Post subject: | Mechanical oil pressure gauge |
I am rebuilding a 1965 /6 225 engine to replace my 74 /6 that is in my truck. The mechanical oil gauge hasn't worked in the five years that I have had the vehicle. The engine on the stand has a npt fitting left of the oil pump which I would access, but the engine in the car, which I would like to access now, has no fitting there. Where would there be a good place to hook up this fitting, and activate my oil pressure gauge for the first time. Thanks...............Gary |
| Author: | Badvert65 [ Sun Jun 21, 2020 5:36 am ] |
| Post subject: | Re: Mechanical oil pressure gauge |
Under the oil filter, on the oil pump, there should be a factory oil pressure sender. Either remove this and replace it with the mechanical sender fitting, or place a 'T' in that spot to use both. |
| Author: | Doctor Dodge [ Sat Jun 27, 2020 10:12 am ] |
The tapped hole in the rear of the main oil galley is a great place to install an oil pressure gauge fitting or sending unit. Many are not tapped so I drill and tap this location when rebuilding an engine. DD
