It is currently Sun May 10, 2026 3:57 pm
 Post subject: fuel injection
PostPosted: Mon Aug 11, 2003 9:50 am
I have thinking about fuel injecting my slant 6 and looked at the tech articles posted on this site. My question has anyone looked at the MPFI off of a 3.0 V6 out of the late 80's Chrysler Mini -vans would this system work as well as the GM conversion ?
 Post subject: Might work, but...
PostPosted: Mon Aug 11, 2003 10:34 am
The chrysler parts are for an engine with a similar displacement; so, it might work. The problem is that the Chrysler computer's firmware is pretty much locked down and the box is epoxy sealed, if I remember correctly (hence the reason you can't get a performance "chip" -- you need a performance module or a performance computer).
The reason a lot of people use one of the GM computers is that the program, or at least the fuel injection map, is on a removeable chip; and, therefore the computer can easily be reprogrammed. These particular computers were common in trucks or any performance oriented car (camaro, turbo buicks, etc) from the late 80's and early 90's. Many of the later GM cars have computers which are locked down (sealed) like the Chryslers.
I'm not sure how much is programmatically adjustable in either the Chrysler or the newer GM's.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Mon Aug 11, 2003 7:48 pm
Pstone,
I used a GM set-up primarily because it is batch fire (I could keep my distributor), and it used a MAF sensor and is therefore self calibrating. Also, because these are abundant in junkyards, and there are some good books on the subject ("How To Repair & Modify Chevrolet Fuel Injection" by Ben Watson) .
I'm not sure, but I believe that the Mopar setup uses fixed speed density calibration. I think that this would make it very difficult to use on an engine with a different volumetric efficiency, even with the same displacement.
Bob D
Users browsing this forum: Nearo123 and 5 guests
