| Password change/dead hole https://slantsix.org/forum/viewtopic.php?t=6520 |
| Author: | trontek [ Mon Aug 11, 2003 2:24 pm ] |
| Post subject: | Password change/dead hole |
posting seems to be hunky-dory now. Thnx admin! New dist. cap,#3 still dead(& #4 seems to be a bit slouchy) Gonna install new intake gasket next. Hear rumor that intake gaskets can be a problem on these engines. Waddya think(since th writin' on th' manifold says no more than 10ft lbs)? Jim |
| Author: | Pierre [ Mon Aug 11, 2003 3:30 pm ] |
Just how are you coming to the conclusion that its a dead cylinder? If you think the intake/exhaust gasket is leaking, spray some carb cleaner in there and see if it makes any difference. |
| Author: | Eric W [ Mon Aug 11, 2003 3:58 pm ] |
Try a new spark plug in #3 and see if that helps. They may look good, but they can be/go bad. |
