It is currently Sat Oct 10, 2026 8:17 am
 Post subject: ACCEPTABLE tolerances
PostPosted: Thu Aug 27, 2020 2:32 pm
Car Model: 1938 Plymouth 4 dr. sedan
I have measured the bores in my /6 for size and roundness, high in the bore and lower. Came up with a big bore diameter of 3.4060" and a small bore of 3.4010" I'm hoping to hone the cylinders and use stock size rings. Any comments, suggestions. Are these acceptable tolerances?
Street rod an old car and then drive/use it. I'm a NSRA safety inspector if anyone ever wants that done to their car.
PostPosted: Fri Aug 28, 2020 11:17 am
My '64 FSM lists the max allowable out-of-round as 0.005" and max allowable taper as 0.010". I think you're good to go.
If you see that full variation at one height in a single bore then you're right up against the out of round limit, but even then I wouldn't sweat it for a stock-ish engine.
Escape Velocity Racing
PostPosted: Fri Aug 28, 2020 1:04 pm
Vote #2 to re-ring / overhaul the engine & run it.
To be honest, I have successfully re-ringed SL6 engines with even more wear, with good results.
PostPosted: Sat Aug 29, 2020 1:39 am
I agree.
Users browsing this forum: Bing [Bot] and 27 guests
