| ACCEPTABLE tolerances https://slantsix.org/forum/viewtopic.php?t=65264 |
| Author: | Mongrel147 [ Thu Aug 27, 2020 2:32 pm ] |
| Post subject: | ACCEPTABLE tolerances |
I have measured the bores in my /6 for size and roundness, high in the bore and lower. Came up with a big bore diameter of 3.4060" and a small bore of 3.4010" I'm hoping to hone the cylinders and use stock size rings. Any comments, suggestions. Are these acceptable tolerances? |
| Author: | SpaceFrank [ Fri Aug 28, 2020 11:17 am ] |
| Post subject: | Re: ACCEPTABLE tolerances |
My '64 FSM lists the max allowable out-of-round as 0.005" and max allowable taper as 0.010". I think you're good to go. If you see that full variation at one height in a single bore then you're right up against the out of round limit, but even then I wouldn't sweat it for a stock-ish engine. |
| Author: | Doctor Dodge [ Fri Aug 28, 2020 1:04 pm ] |
Vote #2 to re-ring / overhaul the engine & run it. To be honest, I have successfully re-ringed SL6 engines with even more wear, with good results. DD |
| Author: | Dart270 [ Sat Aug 29, 2020 1:39 am ] |
I agree. Lou |
