It is currently Thu May 14, 2026 12:29 pm
PostPosted: Tue Aug 12, 2003 10:23 pm
Was working on the Dart again yesterday, and her dad and I were trying to figure out why it was running rough, so he busts out this old oscilliscope that you hook up to the ignition system, and it gives you a waveform of each spark plug's firing pattern and tells you exactly what's wrong.
Though it's what we both suspected: bad wires.
Thing even has a tach built in. I want one of these things!
PostPosted: Tue Aug 12, 2003 10:39 pm
Scopes are indeed nifty tools. I've used handheld ones too.
 Post subject: Check old shops...
PostPosted: Tue Aug 12, 2003 10:42 pm
My buddy got one of those, but it's the cabinet sized roll around one for $50 from a gas station that was 'closing shop'....
Everytime a problem arose with any car he'd roll that thing up and plug it in, you could see variances in the spark in each wire when tested, what the timing looked like, even plotted some weird pattern while the distributor advanced....neat tool, wish I had more on time with one.
cool,
PostPosted: Tue Aug 12, 2003 10:43 pm
Yeah I'd love a handheld one. This one's pretty burly. About the size of a large lunchbox.
could be a great tuning tool, since it tells you when the plug gap is too wide or too narrow. I see much experimenting ahead 8)
PostPosted: Tue Aug 12, 2003 10:51 pm
I have a handheld 4 channel digital scope/multimeter. Can hook it up to the engine, and one person drive, while another looks for the problem. By the time I get proficient with everything it can do, it will be obsolete.
It is even capable of a dynamic compression test based on starter current draw, as each cylinder comes up on compression stroke.
PostPosted: Tue Aug 12, 2003 11:11 pm
What's the name, how much did it cost, and where'd you get it? :P
PostPosted: Wed Aug 13, 2003 5:22 am
It is called "Insite" by interro systems. Purchased through Matco tools, about 5-6 yrs ago. With all the different adapters, approx $4,000. This is not a hobbiest tool. I used to have my own shop, and still have most of my equipment.
PostPosted: Wed Aug 13, 2003 6:59 am
Measuring relative compression based on pattern of starter current draw-now THAT'S a smart idea. I never thought of that, but it makes perfect sense. A word of caution-I wouldn't hook a regular oscilloscope to a sparkplug wire. That sounds like a good way to ruin a perfectly good oscilloscope. I'm sure the automotive type is designed to handle the high voltages present on plug wires.
Everyone driving slower than me is a moron. Everyone driving faster than me is an idiot. With all these morons and idiots on the road, I can't get anywhere!
PostPosted: Wed Aug 13, 2003 1:29 pm
Yeah this is an automotive one, and it's inductive. Clamps onto the outside of the coil wire, and then another part clamps onto whichever plug wire you wanna check.
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
