It is currently Thu Nov 19, 2026 11:51 pm
 Post subject: Fuel tank
PostPosted: Tue Nov 17, 2020 1:08 am
Why won't the fuel ignite when a current is passed through the resister of the fuel guage sender?
I have assumed this is how the sender works.
 Post subject: Re: Fuel tank
PostPosted: Tue Nov 17, 2020 1:27 am
No spark.
Not hot enough.
PostPosted: Tue Nov 17, 2020 1:33 am
I thought so too, but was not sure.
PostPosted: Tue Nov 17, 2020 3:34 am
No oxygen in the tank. It is displaced by fuel liquid/vapor.
PS: Liquid gasoline is not flammable, only the vapor.
PostPosted: Wed Nov 18, 2020 12:49 am
I did not know liquid gasoline was not flammable.
PostPosted: Wed Nov 18, 2020 4:43 am
Car Model: '23 T-bucket
It's true. There have been (very uncommon) instances of a smoker throwing a cigarette butt into gasoline without an expected ignition. If one can get it through the fumes, then the fluid will douse it.
However, the flash point of gasoline, and even the vapor point, is so low that gasoline is considered one of the most hazardous fluids on the planet. (Notwithstanding corrosives and biologicals.)
Shoot, even at 0*F, gasoline is still "out-gassing", or evaporating. (I would have to do some research to find the actual numbers for such info.)
NO! Don't try that at home. :mrgreen:
Roger
PostPosted: Wed Nov 18, 2020 6:25 am
Now about the flash point: gasoline placed in an open bin has a flammable vapour above the surface when temperature of the liquid is – 23 °C (-9.4 f). You can imagine a cloud of gasoline vapour hanging above the surface of the liquid. When a spark or flame hits the vapour, it ignites.
PostPosted: Thu Nov 19, 2020 7:36 am
Car Model: '64 Valiant Convertible
My favorite gasoline vapor example.....
https://www.youtube.com/watch?v=UH4Hw9s8OAM
Enjoy the show!
PostPosted: Fri Nov 20, 2020 2:09 am
What a d head.
I am glad I raised this as a topic.
Thanks for your responses.
