It is currently Fri Jun 19, 2026 4:51 am
PostPosted: Mon Dec 07, 2020 9:15 pm
I'm happy to buy a copy of Doug's book, but I was wondering if it specifically covered aluminum engine servicing or if I need to also buy an early shop manual?
Thanks!
PostPosted: Tue Dec 08, 2020 3:02 am
Yes not like an engine build but it's in there with some pictures. The 63 service manuals have aluminum engines in them at least the Valiant one does.
63 Plymouth Valiant Wagon
PostPosted: Tue Dec 08, 2020 6:54 am
Are there torque specifications?
PostPosted: Tue Dec 08, 2020 4:49 pm
A quote from the 63 service manual (" All bolt torque specifications for the aluminum engine are the same as for cast iron engines with the exception of the main bearing cap bolts which are to be tightened to 50 foot-pounds." )All torque specs are cold and standard caution about cross threading.
PostPosted: Thu Dec 10, 2020 11:14 am
where's mavtv91? he usually is a good service manual guru.
PostPosted: Thu Dec 10, 2020 11:15 am
You also might b able to find some stuff on this site.
http://www.mymopar.com/index.php?pid=109
valuable resources there.
PostPosted: Thu Dec 10, 2020 5:52 pm
Unfortunately the Dodge manuals jump from 1960 to 1966 and the 1960 manual does not cover the aluminum 225. No applicable Plymouth manual either.
PostPosted: Thu Dec 10, 2020 6:42 pm
https://www.ebay.com/itm/1963-Dodge-Dar ... SwlFVdf8Wi
PostPosted: Thu Dec 10, 2020 6:53 pm
https://www.ebay.com/sch/i.html?_from=R ... ual&_pgn=2
PostPosted: Fri Dec 11, 2020 6:54 pm
I have a 62 manual.
I will see if it's there.. Greg
PostPosted: Sun Dec 13, 2020 5:59 pm
Josh,
I gotcha covered!
https://www.slantsix.org/forum/viewtopi ... 19&t=65632
PostPosted: Mon Dec 14, 2020 7:25 pm
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
Josh, I have a 62 Dodge FSM and a copy of Doug's book if that helps you any.
