| Source for triangle manifold washers found! https://slantsix.org/forum/viewtopic.php?t=65692 |
| Author: | Reed [ Thu Jan 07, 2021 2:58 pm ] |
| Post subject: | Source for triangle manifold washers found! |
I thought these were no longer available new, but it looks like I was wrong! https://www.youronlinespeedshop.com/col ... PqZB_a7YN4 I checked, and as of January 7, 2021, shipping from Australia to Washington State, United States, is free. That's a pretty good deal. |
| Author: | Greg Ondayko [ Thu Jan 07, 2021 5:56 pm ] |
| Post subject: | Re: Source for triangle manifold washers found! |
I wonder about structure / rigidity. The original ones were cast? With a dome in em... these look like they are plasma or water jetted out of plate. Good find nonetheless. Greg |
| Author: | '67 Dart 270 [ Sat Jan 09, 2021 6:23 pm ] |
Originals still come up on ebay: https://tinyurl.com/yywty4t4 Brian |
| Author: | '67 Dart 270 [ Sat Jan 09, 2021 6:25 pm ] |
...and these, although way expensive, are closer to original design. https://tinyurl.com/yxglvad9 |
| Author: | Old6rodder [ Sat Jan 09, 2021 10:53 pm ] |
Gennies I have all appear to've been stamped out. |
| Author: | Rick Covalt [ Sun Jan 10, 2021 5:03 am ] |
There are actually 3 different thicknesses that were used over the years also. |
| Author: | Old6rodder [ Sun Jan 10, 2021 7:28 pm ] |
Yep. I use the thin ones for the rocker box & oil pan. |
| Author: | MadScientistMatt [ Mon Jan 11, 2021 7:07 am ] |
Quote: I wonder about structure / rigidity.
If anything, I'm a bit worried about excess rigidity - the stock design uses the cone shape as something like a Bellville spring washer.
