It is currently Tue Nov 17, 2026 3:36 pm
PostPosted: Sat Jan 30, 2021 5:20 am
Car Model: 1968 Barracuda - Fastback
[no longer looking - but can't figure out how to delete this]
I'm looking for a 7.25 sure-grip unit + 3:23 R&P to rebuild my differential.
Will also consider an 8.25 differential assembly with same gearing for my '68 Barracuda.
I know someone recently was looking for the same, hoping there's still something out there :)
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Sat Jan 30, 2021 5:45 am
I don't recommend spending money on a 7 1/4. There just aren't many parts available, any longer. If you are lucky enough to find a SG unit, it will probably need new clutches. If you find the clutches probably over $150. Spider and axle end gears are hard to find, spider gear shafts are made of unobtainium. I have a LBP 7 1/4 I am building, with all new parts. Took me years to find everything, and I have about $500 in it. 3.91 SG with all new parts except the spider shafts (luckily they were in good shape).
