It is currently Tue Nov 17, 2026 8:55 pm
PostPosted: Sat Aug 16, 2003 12:49 pm
I've got this forged 225 motor that I will turbo'ing soon. I need a forged rod/piston combo that will yield me 8.0-8.5:1 compression, with a maximum overbore of 0.030", preferably none.
Is there a combo out there that will work, that won't cost me an arm and a leg and a ton of machine work? I'd like to keep the stock stroke if possible, and I don't really want to do any crank modifications if I can avoid it.
PostPosted: Mon Aug 18, 2003 5:40 am
I'm in the same boat. If you come up with anything let me know. Although I'd like to go with a bigger overbore if I thought I could get away with it.
That group buy idea from that other thread is a good idea. I'd be in for that.
PostPosted: Tue Aug 19, 2003 2:27 pm
using a brass(?) bushing for the con rod pin makes metric pistons useable. I remember Jyri from finnland who had a set of 198rods and bushings to work with VW Pistons, I think i remember something with VW Type III engine ? I think most modern pistons are rather "short" from the top to the pin, so you may need the longer 198ci con rods. Search for "Jyri" at .org and .com.
Users browsing this forum: Bing [Bot] and 5 guests
