It is currently Wed May 13, 2026 8:11 pm
PostPosted: Sun Oct 03, 2021 3:54 am
Car Model: 1963 Signet
I'm in need off a back glass for a 1963 Plymouth Valiant 2 door hard top. I found a 1964 Plymouth Valiant back glass online and they look identical. I'm wondering if anyone knows for sure if they are compatible. Thank you!
And thank you Chuck for creating this form.
PostPosted: Sun Oct 03, 2021 4:08 am
I'm pretty sure 63,64,65 are the same. Someone will probably chime in with a definitive answer.
PostPosted: Sun Oct 03, 2021 9:23 am
64,65, 66 valiant are all different back glass. windshields are the same. don't know about 63.
PostPosted: Sun Oct 03, 2021 9:41 am
Really? I know 66 is an odd ball, but I thought at least 64 and 65 where the same. I have a 64 rear glass in the garage. I'll lay it on top of my 65 and verify. I may be totally wrong!
PostPosted: Sun Oct 03, 2021 3:44 pm
I stand corrected. Rick is right. According to Detroit Muscle Tech, the rear window gasket is the same for 63,64,65 Valiants. That would mean the glass should be the same.
PostPosted: Wed Oct 06, 2021 12:39 am
Thank you for the follow up information, much appreciated! It makes sense that if the window gaskets are the same from 63-65, that this would be a strong indicator the rear glass is that same.
PostPosted: Wed Oct 06, 2021 2:08 am
I'm sorry for the initial wrong info. At my age, the memory sometimes fails me. I have oem parts info, on a thumb drive, but this computer won't read it.
