It is currently Sat May 02, 2026 5:03 am
 Post subject: 8 inch woes
PostPosted: Thu Aug 21, 2003 10:45 am
hey i got a really cheap 8 inch f*** rearend that i want to put in my 1965 barracuda. it had a 7 1/4 in it so i took that out and now the shakles are to small for the ford to fit right so do i need to get new shakles or modify the ones i have, or get ford ones or bigger mopar ones or what???
PostPosted: Thu Aug 21, 2003 1:45 pm
Do you mean the U-bolts? If so, then I think the Ford 8" takes 3" U-bolts and you'll have to buy new ones. Any spring shop will have them, or sometimes PepBoys or other parts stores. They should probably be replaced anyway...
PostPosted: Thu Aug 21, 2003 6:32 pm
If you mean the plates that go under the spring you can either get new ones or get them from a car with an 8 3/4
________
Carina ed
________
Hot Box Vaporizer
