It is currently Mon Nov 09, 2026 12:21 am
PostPosted: Mon Feb 07, 2022 1:52 pm
Car Model: 78’ dodge D100 slant six
Besides putting them on and see if it works is there a bench test? I have several I want to test since I have found my problem. Any ideas? FSM is no help here
PostPosted: Sat Feb 25, 2023 10:50 am
Site Admin
I think that installing them is the only sure way.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sat Mar 04, 2023 3:12 pm
Car Model: 1966 Dodge Dart
You might be able to use an adjustable voltage power supply and a test light. Wire the test light like it's the field coil, see what voltage makes it turn off and on. The function of the regulator is to switch the field coil on below a set voltage, but it may also have some sort of intentional pulse function or other complications.
Matt Cramer
PostPosted: Sat Mar 04, 2023 3:55 pm
You don't mention whether you're trying to test '69-down or '70-up regulators. '70-up regulator test info here and here.
PostPosted: Sat Mar 04, 2023 4:12 pm
Years ago when I worked the parts counter we had an alternator test machine that also had a VR test option, had plug ins for the common Mopar and Ford regulators and alligator clips for any of the point type ones with a different position for each on the tester
PostPosted: Wed Mar 15, 2023 9:32 pm
That YouTube link was one I already watched as well. Thanks for the input Dan. I always appreciate you helping this old man out.
