It is currently Fri Nov 27, 2026 3:43 pm
 Post subject: Cadillac 4.1L V8 pistons
PostPosted: Fri Mar 04, 2022 6:07 pm
Are these pistons of any use in our slant 6 engines?
Looks like they would drastically lower CR. Slants 1.74" vs Cadillacs 1.63" compression heights, not to mention the Caddys dish.
PostPosted: Fri Mar 04, 2022 7:32 pm
The 3.465 bore size works but the 1.63 compression height (+ dish) and the .865 piston pin size are not a good match.
PostPosted: Sat Mar 05, 2022 9:39 am
Thank you, Sir, I appreciate the response.
PostPosted: Sun Mar 06, 2022 3:39 am
You could make these work with a 198 rod and/or with lots of block/head milling, but otherwise Doug is right.
PostPosted: Sun Mar 06, 2022 8:41 am
Yah in a pinch but not worth it..... I saw some for sale cheap and saw the bore size and wondered how close of a direct replacement....thanks
